Tracking oil leak
Old Jan 2, 2009 | 03:25 PM
alw's Avatar
alw
Tracking oil leak
2006 2.4L ~50K miles...I'm trying to track down a new oil leak. Bottom of trans pan is covered in oil. Engine oil pan and drain plug are clean and dry.
Has anyone else had this? maybe a TSB or something.
I saw the TSB on the 2.2L oil galley plugs leaking. I'm hoping this one is not a rear main seal.
Old Jan 4, 2009 | 12:12 PM
mister hhr's Avatar
changed oil yesterday and noticed a small oil leak wiped it off will keep a watch to see if I can find the source.
Old Jan 4, 2009 | 12:43 PM
dbfruth's Avatar
I had a oil seal go bad on the half shaft at the transmission. It threw a bunch of oil around at the trans.
Old Jan 4, 2009 | 04:15 PM
catdaddy137's Avatar
sorry i can't help you
i changed my oil yesterday also . 08 2.4 . i also noticed what looked like something leaking around the driveshaft housing. could you tell if it was oil for sure? or maybe trans fluid. since the trans is sealed i don't know how to check it or what the trans fluid looks like. i'm guessing , yours and mine may be the same problem the other person listed here-driveshaft seal. i hope not a didn't spend so much $ on my hhr to have to work on it. the reason i got it was because i have too many projects and don't need anouther. is the driveshaft seal covered under the powertrain warrantee?
Old Jan 4, 2009 | 04:22 PM
dbfruth's Avatar
The driveshaft seal is covered under the powertrain warranty. I could tell it was the drive shaft due to the oil radiating out from the seal area. since it was throwing the oil I could not determine the color but I am sure it was tranny fluid. You should be a look in through the wheel well and clearly see the seal area
1970judge
Aug 14, 2015 05:47 PM
hurst2001
Aug 4, 2013 04:45 PM
blomb
Jul 3, 2008 11:30 AM
pobryne
Jun 5, 2008 09:47 PM
freshone
Mar 27, 2006 11:58 AM
