Traction Control problem
Old 01-13-2008, 02:58 PM
  #31
Lee3333's Avatar
I have the same problem with the T/C light coming on, and the same MAP code. I have tried 2 dealers, both refusing to change the MAP due to my CGS intake. I did it myself, and still get the T/C light and the MAP code. Since my car got hit last year in the right rear wheel, I am trying to get an appointment with the dealer to check that sensor to see if it could be causing an errant code caused by a bad ground (this was suggested to me by several mechanics).
Lee3333 is offline
Old 09-19-2008, 05:26 PM
  #32
Airborne_Beachbum's Avatar
I just recently had the issue of hard shifts and the T/C light coming on and staying on. Like everyone else's, mine will reset after turning the car for awhile. It is totally random when it happens; I've had it happen when I drive it hard or baby it.
Airborne_Beachbum is offline
Old 09-19-2008, 06:12 PM
  #33
We've had the GMPP intake, switched out the CGS, on Bonnie's car for a month or so now and we haven't seen any T/C issues or other codes. Hopefully this did the trick.
GDZHHR is offline
Old 01-08-2009, 08:38 PM
  #34
egadgetguy's Avatar
Just wanted to add, as I said in another post, I fixed my T/C off +hard shift problem. All I did was reseat the relays and fuses, which were loose, under the hood. I had the problem on every trip before that and Since then, I have not seen the problem.
egadgetguy is offline
Old 01-12-2009, 09:02 AM
  #35
Lee3333's Avatar
That would really be wonderful it it also works for me. I will check them all later.
Lee3333 is offline
Old 06-30-2009, 10:39 AM
  #36
egadgetguy's Avatar
Not fixed: T/C light
UPdate... This was not the fix! There was a brief time where it looked like it was fixed but the problem returned. I think it might be the MAF sensor, and I am taking it in next week... Seems like a common problem...
gio89kid
02-17-2015 08:15 PM
fine69
Drivetrain (Excluding Engine)
01-11-2014 11:18 AM
catncarp
11
12-12-2013 03:27 PM
Christinag1125
12-10-2013 12:15 AM
andoll83
06-23-2010 07:28 PM
Quick Reply: Traction Control problem
