Starter issues
Old 09-17-2018, 10:37 AM
Travis Lee Drenner's Avatar
Starter issues
I have a 2009 hhr with the 2.4.
starter wouldn't work so I replaced it , and now it still wont start I have replaced ign switch with no change , theft lock light is lit , tried 3 times to do the computer reset with no change checked all relays and such ..... the starter is good I jumped it over it will crank and start but dies within seconds ... what am i missing ....I'm about to pull my hair out help!!!
Travis Lee Drenner is offline
Old 09-17-2018, 11:11 AM
Technical Moderator
Did you consider checking the battery? I don't care how old it is or if the lights work. It needs to have 12.6 volts.
donbrew is offline
Old 09-17-2018, 11:48 AM
Welcome to the site, X2
Oldblue is offline
Old 09-17-2018, 11:56 AM
X3. Check the voltage.
Above(in blue) may be the theft module is shutting it down.
firemangeorge is offline
Old 09-17-2018, 12:11 PM
Check the underhood fuse box, ground wires connections, something got knocked loose while you where in there.
Oldblue is offline
2005HHRauto
2.0L Performance Tech
07-03-2016 10:44 AM
LuckyLadySD
06-12-2014 02:09 AM
nabate
07-15-2006 07:41 AM
adamlowery
05-03-2006 09:20 AM
mrbcruzn
04-20-2006 04:31 PM
Quick Reply: Starter issues
