Transmission not responding when shifting into gear
Old Mar 10, 2024 | 09:47 PM
gmorris0303's Avatar
I recently replaced a shift solenoid on my 2007 Chevrolet HHR LT 2.4L Automatic Trans after finding it all burnt up and melted to its plug in (Wiring Harness). After I put everything back together and went to shift the car into gear, there was no response at all. I read and noticed someone else had a similar issue (only they were going forward in all gear’s including park) and they found that it was the bottom linkage on the inside of the transmission right next to the shift solenoid that was not attached.
I already replaced the shift cable on top of the transmission, that being said, any thoughts or suggestions? Or is my suspicion correct and I should check the linkage inside the tranny?
Old Mar 11, 2024 | 08:44 AM
I’m thinking your suspicion is correct
Old Mar 11, 2024 | 11:52 AM
What caused the original melting? That is the reason.
Jace1283
Jul 20, 2023 04:15 PM
Gearhead1
Feb 20, 2022 06:23 PM
sklute
May 17, 2015 02:27 PM
Talvanos
2.2L Performance Tech
15
Feb 7, 2010 10:02 AM
Unclesams_SS
Jun 7, 2008 11:14 PM
