transmission wont shift into drive from second gear
I have the same issue as above I believe.
I own a 2010 HHR with only 45k miles. I can shift the transmission with the shifter into 1st, then up to 2nd. If I start in D, it will go from 1 - 2 but not into Drive.
Any ideas that I can try in order to repair?
You could look at the the shift cable and you might see something obviously wrong. You could check that the wiring harness between the trans and the Trans Control Module has a good connection at both ends and no frayed/burned/shorted wires.
The TCM is the smaller of the 2 modules in front of the underhood fuse box.
Hey Jvaz2000,
Glad you're reaching out here, but as donbrew said, if you'd like to have your shifting issue addressed by your local Chevrolet dealership, I would be happy to assist you with that. Just PM me with your VIN, preferred dealership and contact information and I'll share your concerns with them. They'll reach out to you to set up a service appointment.
Let me know if this is something you'd like to do. I'll be on the lookout for a message from you. Also, I'd be happy to assist if you have any additional questions.
Geoff G.
Chevrolet Customer Care
Geoff G.
ImNewHere
Jul 31, 2014 07:22 PM
Decoteau
Sep 5, 2013 05:18 PM
johncin13
Nov 26, 2010 06:24 PM
