Chevy HHR Network
-   -   Turn signal canceling (https://www.chevyhhr.net/forums/problems-service-repairs-42/turn-signal-canceling-56149/)
lasater Feb 7, 2016 08:18 PM
Turn signals stopped cancelling so I replaced the lever/turn signal switch with a new OEM unit. No change. Still won't cancel. Any ideas???
firemangeorge Feb 7, 2016 09:03 PM
Ok. Haven't had one out in a HHR but shouldn't there be a lobe, knob or whatever that triggers the cancellation ?
Something fixed to the column that turns with the column ?
Come on Cliff. I figured with your skills you would be able to figure this one out by yourself. :wink:
lasater Feb 7, 2016 09:21 PM
Yeah, I just didn't want to tear into it again. I was hoping there was an old Indian trick or an ancient Chinese secret to it. Honestly, I'm so busy with the V8 build I really don't want to spend any time doing anything past an oil change on my daily driver. I guess I'll have to pull it back apart and strip the colum down to find out what activates the turn signal cancellation.
firemangeorge Feb 7, 2016 09:43 PM
Cliff. Try this link, post #23. It may help. https://www.chevyhhr.net/forums/how-...s-37992/page3/
whopper Feb 7, 2016 10:59 PM
Dang - ya beat me to it FMG. :)
Oldblue Feb 8, 2016 08:36 AM
You shouldn't need to tear into the column. Jut remove the switch and make sure the cancel tab is engaged
donbrew Feb 8, 2016 09:00 AM
I have a feeling that if it's that black plastic bit on the column that broke it means a new steering column.
