Underhood Fuses Tip
I was thinking about painting the Fuse Box Cover and the other part right in front of it. They both come off easy.
this should be stickied!
-WC |
If JonelZ makes a "Tech Tips" section, we could stick it there. If I come across anything else that seems relevant I'll post it there. But only if you guys feel this type of thing is helpful. :thumb:
-Mike |
We are still growing along. With Great Members like yourself and the others this site can be an ultimate resource towards the HHR.
Heck yea. All this kind of info is helpful. I also think there should be a type of tech tips section. It'd be nice.
I was finally able to get under the hood of my "lil hearse" today and what did I find? All but one of my fuses and relays were loose. A full inspection is coming soon.
I was checking my oil and remembered reading these messages. Checked and lo and behold.......every fuse, breaker, and relay loose. My son, who works in manufacturing figures they are placed into the panel by some type of pneumatic press that uses a set pressure. That would explain the uniform looseness. You would think that when they installed the panel under the hood they would check everything. Maybe it's time to forget NAFTA and get the jobs back to the USA.
just checked mine and every one of them was loose.
