Uneven Brake pad wear 2006 LS
Old Jun 27, 2014 | 02:16 PM
MikeRuth's Avatar
Hi folks, took my tires off to rotate and inspect brake pads today and found that the right hand front pads are roughly 20 to 25% more worn than the left./
Any idea as to why this might happen?
The pads are the second set, OEM changed about 55K to these from Kragen. I'm totally satisfied with the longevity of the pads and performance.
Old Jun 27, 2014 | 02:42 PM
Dragging caliper.
Old Jul 10, 2014 | 06:01 PM
MikeRuth's Avatar
Thanks for the thought.
that would be from? caliper not floating as it should?
Piston binding?
Old Jul 11, 2014 | 03:24 AM
geg's Avatar
geg
I AFRAID, you need to disassemble the caliper with a view to piston revision.
Piston may not work for some reason:
1. Rubber sleeve destroyed. Dirt penetrated into the slot of the piston. Scratched the surface of the piston and the piston moves out of alignment.
2. Your pads were thin. Piston strongly sticking out of its socket and partially covered with rust. After replacement brake pads - piston gone deep into the nest and rusty surface prevents smooth movement.
The first is treated by replacing, the second - a simple polishing.
But do not disassemble your calipers immediately, first listen to your feelings. If you feel the vibration when braking - your calipers (or discs) real sick.
Another possible - uneven pressure fluid in the lines. But this - higher mathematics. I do not know the reasons and methods of treatment.
Old Jul 11, 2014 | 06:06 PM
Either as geg says bad calipers/binding slides or, bad hub can do it.
Franco Fanfuria
Aug 28, 2014 08:22 PM
hozer
Aug 18, 2012 02:46 PM
MajorSpittle
Mar 11, 2011 05:09 PM
Neal Sweeney
May 21, 2010 06:31 PM
lrg760
Tires & Wheels
22
Jun 4, 2007 08:45 PM
