Unlock With Key- Stop The Beeping
Old Jan 25, 2026 | 07:31 PM
Bird Doo Head's Avatar
Hi All!
Until I can replace my non-functioning key fob for the 2006 HHR, I use the key to unlock the car. When I do that, the horn continuously beeps until I get in and turn the key on. After searching the manual, I could not find a way to disable the beeping. (Often I have to unlock when people are sleeping. Don't wish to wake them.)
Do any of you know if there is a way to disable the horn when the key is used to unlock the door?
Thanks For Helping,
Paul
PS: It might be a while until I get a fob. The fob is inexpensive, but the best price I've found to program it is $300.00. Yikes!
Old Jan 25, 2026 | 08:00 PM
fastsuv's Avatar
Dorman makes a key fob and programmer kit for the HHR.
You plug the programmer into the OBD II port and follow directions. I think it will program 3 key fobs and then deactivates the programmer. I have successfully used it in the past.
Check Dorman web site to be sure this is the right kit for the HHR (I'm pretty sure it is).
Price is $60 on Amazon or around $85 at local parts stores.
Steve
Dorman HHR Key Fob Dorman HHR Key Fob
Old Jan 26, 2026 | 08:05 AM
Lonwane's Avatar
Use the key to lock the.car,
Old Jan 26, 2026 | 08:10 AM
When you lock it don't use the lock button use your key. Locking with the fob or the "lock all" button activates the alarm, the key does not.
If you go the Dorman route get a genuine GM fob to go with the included fob. Many of the included fobs don't function properly.
Old Jan 26, 2026 | 09:52 AM
oldmanHHR's Avatar
Using the key to lock the driver door, will it lock the other doors too or just the driver door ?
Old Jan 26, 2026 | 11:21 AM
Just the driver door
Old Jan 26, 2026 | 11:34 AM
Thanks Fastsuv for the information about the programmer. It sure is less expensive than having it done.
Thanks Again,
Paul
Old Jan 26, 2026 | 11:36 AM
Thanks Don Brew & Lonwane for the information about skipping the Lock button & using the key. It certainly did stop the beeping when I unlock.
Old Jan 26, 2026 | 11:37 AM
Just the driver door, oldmanHHR. Then, I use the button on the door to unlock the other doors & hatch.
Old Jan 26, 2026 | 02:58 PM
But who is oldmanHHR ?
