Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Ok, I will just say it, I'm a dunce. Top of engine under air filter box. Next to cylinder 1 is a small box with a vacuum line in front and back and they use snap on connections. WTF is that thing called? I need to get it and likely the lines replaced cause the air leak is causing havock on my engine. Please help me.
