Chevy HHR Network
-   -   Valve cover gasket replacement (https://www.chevyhhr.net/forums/problems-service-repairs-42/valve-cover-gasket-replacement-66497/)
guppy Oct 21, 2023 04:08 PM
VALVE COVER GASKET REPLACEMENT
Broke all three plastic clips in the valve cover
How do you remove the broken parts?
Do you replace the plastic clips or is there a better alternative?
Valve cover bolt grommets. Do these need to get pressed back into the valve cover or is torque the bolt suffice?
donbrew Oct 21, 2023 04:17 PM
What plastic clips? Do you mean the ones that hold the wires and tubes? A picture might help.
Just press all of the rubber bits into the slots then torque.
Oldblue Oct 21, 2023 05:22 PM
There are replacement tie wraps available for those plastic clips.
I push the grommets into their place then install the valve cover and torque to 89 inch lbs
