Weird Fan Problem
Hello,
Great site for us HHR people! Saved me a ton of time already! I searched and didn't find anything, so here goes. It was really cold here this morning, south of Richmond, VA, and when I got in the car to go to work; the defrost fan wasn't blowing. Everything looked and sounded normal, clutch was kicking in and out on the compressor but no air coming out the vents; until I kicked it up on high, then it started working! :confused: So, I went on to work, fiddling with it the whole time (once the windows thawed out! :D ). Nothing on any setting but high. I checked all the fuses, diodes, and do dads at lunch and didn't see anything weird or out of the way. It still works, but just on the highest setting. :red: Anyone else had this? Thanks in advance! Jimmy F |
ah,
Silly me! Searched for the wrong term. Think I figured it out. |
Sounds like a blown blower resistor, possibly accompanied with a water leak at the cowl.
Hey Chevy Mgr,
Thanks for the reply! Once I searched for the correct terms :roll: I found what I needed. I haven't had a chance to check that butyl patch yet. There has never been a problem with moisture on the floor or on the windows, but I'm definitely going to check. The car is an 06 1LT with, :eek: 93,000 on her. I was, WAS, a route salesman and had a huge territory. She's been a great car with no problems, but don't it figure; I just paid her off! :lol: :nuts: :thumb: But, she's done a lot for me; now it's time for me to do a little for her. |
I have the same problem. It just started a few days ago. Coincidentally, I had a bunch of snow come in off the sunroof when I opened it and it melted on the passenger side floor. Could that be a culprit??
Originally Posted by dbranga
(Post 362352)
These blower motor resistor don't always have to get wet to fail, somtimes they just fail. ;)
Lucky is correct. I just replaced the heater fan resistor last week. No evidence of any water damage anywhere. Probably just old age after 81,000 miles.
I just dropped mine of at the dealer this afternoon for the fan problem as well as the all too common noise from the front end.
I just picked mine up from the dealer. It had a blown reistor and blower motor. They replaced it for $430. Also, I have been having the same squeaking noise as everyone else in the front end. Last time I took it to the dealer, the repaired somehting to do with the steering column. Today they repaired the sway bars for another $200. I bought the extended warranty when I bought the car. The total bill was $650. The warranty covered $450.
| All times are GMT -5. The time now is 06:51 AM. |
