Wheel bearing? noise at 83,000 miles
There's a new buzz or humming sound up front that increases with road speed and it sounds to me like it could be a wheel bearing:
Warranty? maybe: DIY job in my garage? How much does a new wheel bearing cost? Hope its not a noise in the 5-speed stick shift trans. |
I replaced both W/O Warranty myself. It cost me $400 each one (in the south is more expensive). You are going to need:
- A break bar. - 29 mm socket to remove the axle nut. - 15 mm socket to remove the bearing from the steering knuckle. YouŽll be impressed that is easier. |
