Wheel Thumping While Driving?
I’m getting a clunking or thumping while I drive. Its happening when I drive straight. And I can feel my steering wheel moving side to side along with the thump. . I changed the strut. And the lower control arm and I’m still getting the issues. Anyone have any ideas as what it could be?
You're going to have to give us more information. Does it increase proportionately with vehicle speed? Or engine speed? Is it steady and rhythmic, or is it a random thump?
Did you go through the thread that is linked to in donbrew's signature?
Video is not absolute in the sound department, did you change both sides LCA’s and struts?
you might be if you only did the one side. I highly recommend always changing both sides, so order a pair of hubs.
At RockAuto they give us a discount, go to market place click on supporting vendors look at the first sticky thread.
I suggest you double check the torque on the rear LCA bolts. 74 ft lbs , then 180 degrees more
