Window issue in cold weather
Old Mar 16, 2007 | 11:31 AM
454Taylor's Avatar
I understand snow, ice, or frost making the front windows not operate. This morning it was 25 degrees here, there was no visible frost, neither front window would go down. The rear ones both worked. I tried the button every few minutes for over 20 minutes, finally (after warmup?) they opened. You could hear the motors trying to work. Could the rubber be too tight when cold? Could the motor just be too weak? Has anyone experienced this issue? Does anyone know a work around? It would be tough to use a drive thru during this time.
Thanks
Old Mar 16, 2007 | 11:48 AM
Check this thread for possible solution: https://www.chevyhhr.net/forums/show...ht=window+open
Old Mar 16, 2007 | 12:15 PM
Black Rose's Avatar
I've had this happen before.
If the windows are wet when you roll them up and then it gets really cold, the window glass will freeze to the window liner material.
Old Mar 16, 2007 | 01:21 PM
GCarp's Avatar
I had a Datsun (Nissan) pickup that had a problem with the door locks freezing in the cold weather... turned out to be the sound deadening material they sprayed inside the door got all over the mechanism and turned into a rock when it was cold out. Carbeuretor cleaner did wonders for that one...
Old Mar 16, 2007 | 01:29 PM
454Taylor's Avatar
Thanks for the thread lead. I will try the silicone trick. No rain or moisture seemed involved this morning at all and the rears both worked fine. It almost had to be tight rubber...not necessarly a bad thing.
Old Mar 17, 2007 | 05:58 AM
454Taylor's Avatar
Looks like there is a felt material all around the inside area of the rubber where it contacts the glass. Won't the silicone leave streaks all over the glass if it gets on the non rubber felt material?
Old Mar 17, 2007 | 12:19 PM
You might want to send Desert Coyote a pm and ask him since he is the one that gave the suggestion.
Old Mar 17, 2007 | 12:34 PM
ChevyGrlAlways's Avatar
Thanks
lucky you that yours was unfrozen in 20 mins the first time it happened it was abt 1 hour the second time was 40 mins
CarlsSS
33
Apr 5, 2024 04:17 PM
Tyler Harvey
Jun 23, 2011 03:21 PM
ouhockeyplayer
29
Mar 9, 2010 08:16 PM
Big Rad
Dec 28, 2009 10:02 AM
fastsuv
Feb 12, 2008 10:57 AM
