Window Washers Out
Old 04-30-2012, 06:32 PM
geesh's Avatar
sounds like its the windshield washer pump. I replaced mine at 280,000 kilometers, it was a 5 minute repair.
geesh is offline
Old 05-01-2012, 06:39 AM
baldrodder's Avatar
My pump does the same thing with some regularity, just quits pumping. A few minutes later (or a pothole or two later) it's fine again. I'm fairly certain my problem is just a bad connection or wire at the pump though. I changed the air filter one day and must have bumped it, opened the hood and re-bumped the wires and it started working again When I have time I'll actually fix it :)
baldrodder is offline
Old 05-01-2012, 08:50 PM
chuckbear's Avatar
Finally just took it to the dealer today. It turns out to be the pump and of course they won't have one until tomorrow. It also turns out that there is a recall for my ignition so they gave me a loner for a couple of days. I'm going to have to drive around in a damn brand new Camero. I guess I will tough it out since it's only for a day or so. Chuck
chuckbear is offline
Old 05-02-2012, 12:34 PM
Thank you for sharing the updates. Wow, a new Camaro? That is going to be tough to drive around in! LOL How do you like it?
ChevroletCustomerService is offline
Old 05-03-2012, 03:54 PM
Technical Moderator
It took my dealer a week to get the part, no loaner. They insisted on keeping the car "in case the part shows up"
donbrew is offline
Old 05-03-2012, 04:06 PM
2manyvans's Avatar
Will they replace the ignition switch without it going bad? I thought they only replaced it when it went bad... John
2manyvans is offline
Old 05-03-2012, 05:26 PM
chuckbear's Avatar
Michelle, I really liked the car but if I owned one I would really get into trouble. It is fast and everyone else on the road wants to race with you. It does burn a whole lot more gas than my HHR.
John, They did replace the ignition switch. I didn't know about the recall until they told me when I went in for this service. I have not had a problem with the ignition. I was told that the problem was a spring that "could" fall out and the key would be stuck in the switch. All in all they did a great job and gave me the loaner car instead of waiting or bringing the car back. Chuck
Old 05-03-2012, 06:54 PM
2manyvans's Avatar
It's good that everything worked out allright! I'll have to check into the recall- but I bet the dealer won't give me a fast car to race everyone with.... They know me too well... John
MarkSTeinCA
03-19-2019 04:21 PM
sargechris
11-26-2009 05:13 PM
Lee3333
11-20-2007 07:28 PM
enri9267
09-24-2007 12:47 AM
Lone_Star
07-31-2007 12:08 PM
Quick Reply: Window Washers Out
