Window Washers Out
Window Washers Out
Both my windshield and back window washers stopped working on my 2010 Panel. The wipers move but no fluid is coming out and the pumps don't run. The trouble is I can't tell which of the fuses or whatever these things are in the fuse panel, are out, if that's the problem. Chuck
A Stupid question, there is fluid in the tank? Second there is an odd sort of valving at the pump that controls front or rear and the pump itself.
I agree about sitting and waiting for the dealer, but you don't have to pay them for the bad coffee or bad TV. They don't pay you for your time, but......there is always the Hot Chick in a Mini-Skirt running around the kiosk pretending to do work! I know you looked!
The pump itself could be bad, mine was when I went back because it was not holding the water. It turned out that my "Certified" used car had been nearly totaled on the RF and nobody ever looked at the washer bottle assembly. (clue #2, clue #1 was no paint on the bolts holding the fenders and hood on).
