Chevy HHR Network
-   -   Windshield Cowl Not Flush with Windshield, is this a problem? (https://www.chevyhhr.net/forums/problems-service-repairs-42/windshield-cowl-not-flush-windshield-problem-65236/)
ryleyb Apr 13, 2022 09:12 PM
Hello there! I am new to the forum but had a quick question. I have a 2009 HHR LS, and today I had to change my wiper transmission for my windshield wiper that stopped working. In order to do this, I had to take my windshield cowl off. After putting it all back together and putting the screws holding the cowl in place back in, I notice the cowl isnt flush with the windshield in a few spots. Is this normal, or is it a cause for concern? I know older HHRs had the issue with the Cowl Water Deflector in front of the cabin air filter, so I figured maybe it wasn’t a water tight seal to begin with. Thanks!
greg8453 Apr 13, 2022 09:48 PM
I suppose you'll find out. If you installed it correctly I wouldn't worry about it.
firemangeorge Apr 13, 2022 09:56 PM
I've had mine off several times. Always went back on flush.
My guess is you don't have it "seated" straight or something is in the way of it.== The washer tubing. A forgotten tool. Acorn left in the way.
I would take it back off and have a look.
ryleyb Apr 13, 2022 10:16 PM
From what I could tell I had the washer tubing and wiring harness all clipped in correctly. If I pushed down on the spots that weren’t flush, they wouldn’t need much force to be flush, they just wouldn’t stay that way. I am started to wonder if mine is just old and getting brittle, the sealing end is semi hard like plastic, not sure if that’s normal. I’ll take a look tomorrow. Thanks!
geg Apr 14, 2022 12:18 AM
take pictures of problem areas and a general view - then your concern will be clear and reasonable opinions and advice will appear
donbrew Apr 14, 2022 07:38 AM
It does not do anything towards sealing anything out (maybe leaves), it is just "window dressing".
Only 2006 and early 2007 had the butyl patch.
I am amused by the people that put RTV all along the window.
jimvw Apr 14, 2022 08:37 AM
Yup, mine had the RTV along the cowl, and cracks in the butyl patch. so even the added sealant didn't help much I'd guess. I fixed the patch and cleaned off all the sealant on the cowl and windshield. (06 HHR)
ryleyb Apr 14, 2022 08:50 AM
Okay perfect, I thought I saw something about there being a hole near the cabin air filter that allows water to drain out, which led me to think that it didn’t do anything to actually seal water, I just wanted to be sure. Of course my wiper failed on the one day it rained all day! It rained through the night and I did not see any wet spots inside the cab, but I am glad you could confirm it for me. Thanks so much!
ryleyb Apr 14, 2022 08:51 AM
Luckily they made the wipers and cowl very easy to get off on these cars! 10 minute job, can’t beat that.
donbrew Apr 14, 2022 10:13 AM
The drains can get clogged. jimvw posted this pic:
https://cimg6.ibsrv.net/gimg/www.che...492a88d2b2.jpg
