Windshield Wiper Problem
Hey Y'all,
I'm wondering if anyone has experienced any problems with the windshield wipers not wanting to work? I've noticed a couple times on my HHR the wipers not working properly. When I turn on the wipers (to intermittent) sometimes the wipers won't make an initial sweep. Sometimes the wipers will begin to move up across the windshield but will stop after about 2 inches. After the regular intermittent delay the wipers will work on the second and subsequent strokes. If I move the wipers to the on position (slow or fast) they will work right away as well. I've also noticed similar behaviour when I pull the wiper switch down (ie. to make a single pass to clear the windshield.) Sometimes I have to pull the wiper stalk down a half dozen times before the wipers will actually make a pass. The wipers seem to always work fine when I push the button to spray/mist and wipe the windshield. Could this problem be related to some sort of faulty wiring or bad connection? I'm worried about possibly losing all use of my wipers and I really don't want that to happen especially with winter coming up. It can get very slushy and dirty here in the winter and if I couldn't clear my windshield I could be in big trouble. |
I don't know much about this type stuff, but to me, wouldn't that sound like wiring, or a switch or something.... Because the wipers do work, as shown by when you use the washer, so I wouldn't think it's the motor....
I'm sure someone else might be able to shed a little more light... |
My truck had a similiar problem. It ended up being damaged solder joints on the pulse board. Only option was to replace the board or the entire motor.
Probably something similiar here. |
Originally Posted by solman98
(Post 416943)
Probably something similiar here. I'm having a look at gmpartsdirect right now and they list a "module" and a "wiper motor". This pulse board that you mentioned would that be the same as the "module"? It doesn't seem to be too expensive (only $50 on GMPartsDirect.) I'm assuming this module and motor and other wiper components should be easy to access by removing the black cowl under the windshield at the rear of the engine compartment. |
Originally Posted by calgaryhhr
(Post 416948)
Was that an expensive repair? Is that something that can be done easily in the driveway or would it be best to let the mechanic tackle this problem?
But might be worth taking a look. No clue as to what a replacement motor for the HHR costs. |
(Post 416952)
If it is the same, and your good with an iron, then probably not hard. Mine was covered under a recall, but I had already replaced the motor. The pulse board came out as a result of the recall.
(Post 416959)
I'm not sure what a replacement motor costs either. GMPartsDirect didn't list a motor only the module.
http://motors.shop.ebay.com/__?_from...+motor&_sacat= Actually pretty cheap. If you swap it out, I'd go ahead and do the plastic cowl area repair for leaks. |
(Post 416930)
Hey Y'all,
I'm wondering if anyone has experienced any problems with the windshield wipers not wanting to work? I've also noticed similar behaviour when I pull the wiper switch down (ie. to make a single pass to clear the windshield.) Sometimes I have to pull the wiper stalk down a half dozen times before the wipers will actually make a pass. The wipers seem to always work fine when I push the button to spray/mist and wipe the windshield. Could this problem be related to some sort of faulty wiring or bad connection? I'm worried about possibly losing all use of my wipers and I really don't want that to happen especially with winter coming up. It can get very slushy and dirty here in the winter and if I couldn't clear my windshield I could be in big trouble. |
I had this issue with my wipers. I took a video with my camera and showed it to my service manager because I didn't think he'd believe me. They had to replaced the BCM as they told me the BCM was not always sending the command to turn the wipers on when in intermittent. Have not had any problems since the replacement.
I don't want to have to replace the BCM (I think that is a costly repair.) I think I'll live with this irritating condition for now and hope that the wipers are reliable in the low and high speed setting.
If those decide to start crapping out then I'll look into a repair. |
