Windshield wiper spray
Old Jan 8, 2012 | 01:34 PM
bigjoe's Avatar
My windshield wipers work, but I am unable to use the spray to clean my windshield. Does that have a fuse or is the wiper spray motor gone bad?
Thanks
Joe
Old Jan 8, 2012 | 02:07 PM
Old Lar's Avatar
It could be as simple as the spray nozzel is clogged. I had one develope a plug. I did have to remove the front shroud around the wipers to get at the spray nozzel.
Old Jan 8, 2012 | 02:19 PM
bigjoe's Avatar
Thanks. When I press the bbutton I dont even hear the little motor noise it makes when it
shoots the fluid out. Not even coming out on the rear side.
Old Jan 8, 2012 | 02:26 PM
Snoopy's Avatar
You also might want to check the under hood fuse compartment. Look at fuses 39, 48 & 49. I think they are listed as "Wiper Pump" (don't ask me why they have so many).
Old Jan 8, 2012 | 02:40 PM
bigjoe's Avatar
Thanks I will take a look in a few!
Old Feb 27, 2012 | 08:21 AM
SaeTech's Avatar
Did you ever find out what it was? My sprayed fine till this morning it wouldn't spray. I just added me windshield wiper fluid.
Old Jan 12, 2013 | 05:50 PM
dbranga's Avatar
mine just did the same thing last week. I think it is the washer motor. No sound at all. And to top it off, one of my wipers just quit working!
Old Jan 13, 2013 | 12:06 AM
Snoopy-
my '08 O.M. may differ, but it says (underhood fuse box) # 39 is a Relay for Windshield washer pump.
# 48 is a Relay for Rear window washer pump.
& # 49 is a Fuse for windshield washer pump.
Just sayin..
SaeTech- & dbranga-
Fuses & relays are cheaper than throwing parts at it with out checking..
Old Jan 14, 2013 | 11:16 AM
dbranga - re: one wiper not working - check this link on a possible cause and fix -https://www.chevyhhr.net/forums/showthread.php?t=32975
Old Jan 14, 2013 | 06:33 PM
dbranga's Avatar
Thanks!
