whats the biggest engine?
What is the biggest engine that can fit in replace of the 2.4L Ecotec. with fewest modification or is there a way to get my 2.4 to 300hp cause im shooting for +300
to my knowledge (limited as it is) there is CURRENTLY no way to get to 300. HOWEVER, time may solve that little problem with proper tuning for turbo's and other such upgrades.
you could fit a v6 in there?
Originally Posted by sunburstchris
(Post 132585)
How 'bout an LS4? Probably have to fabricate a new power cradle, but it'd probably fit. Those are 303 HP stock.
Hahn Racecraft will probably have a turbo kit soon that'll pull close to that once they get the computer issues worked out. |
easiest route may be using the 2.0 litre & turbo (juiced up).....
Originally Posted by SSguy
(Post 134577)
Or the Hahn people. But, any way around it...well set up turbo, an engine swap to 2.0, or anything else...you'll spend about $5000+ for 300HP, if it is set up properly and done "cleanly". |
throw something japanese under the hood...
go with injectors, intake, header, exhaust, tune, cams, and NOS :)
i have actually thought about putting a b series engine in one
