Hydraulic floor jacks - 2 ton sufficient?
Old Mar 28, 2007 | 11:15 AM
Black Rose's Avatar
Since the HHR is equipped with the OLM, oil changes no longer coincide with mileage for tire rotations and I'm not going to pay a premium just for a tire rottaion, so..............
I am looking at picking up a hydraulic floor jack to make tire rotations easier.
Will a 2 ton Hydraulic floor jack be sufficient to safely lift the HHR? I think it will, but thought I'd ask.
Also, where on the rear axle would be the best location to use jack stands?
Old Mar 28, 2007 | 11:32 AM
Firewatcher's Avatar
I would think it would be more than sufficient. Of course, unless your pet elephant is sitting in the HHR while you are trying to jack it.
Old Mar 28, 2007 | 11:53 AM
krishaynes's Avatar
You'll be fine with a 2-ton jack. Remember, you're only lifting a portion of the car!
Old Mar 28, 2007 | 11:59 AM
Black Rose....
I use a 2 ton rated hydraulic jack. Don't seem to have any problems (been using it for 8-10 years...but, I am due for a new one...has a slight pressure leak).
I lift each wheel individually using the cradle or suspension mounts. Wasn't comfortable lifting from the middle of the rear axle. It's a bit precarious.
But, my routine is different than most people. When I rotate tires, I put the car on jack stands so I can also clean and polish the wheels inside and out, and clean and polish the plastic liners of the fender wells. It takes a couple of hours.
Old Mar 28, 2007 | 12:08 PM
krishaynes's Avatar
Snoopy has the best idea (I was just focusing on the 2-ton jack's ability to lift). You'll want to lift the car in stages and use jack stands. It is safer, and you have the opportunity to clean/look for problems.
Old Mar 28, 2007 | 01:44 PM
Black Rose's Avatar
But, my routine is different than most people. When I rotate tires, I put the car on jack stands...
Now that the glaciers have receded for the winter, I can finally do something with the stockpile of parts I have in the house
I haven't crawled under the beast yet to take a look around to see the jacking points, best place for jack stands, etc. Where do you place the jack stands?
Kind of dumb questions I know, but this is the first vehicle I have had in years that I want to work on. I'm scaring my wife...she thinks this is my mid-life crisis
Old Mar 28, 2007 | 02:53 PM
fastsuv's Avatar
Don't buy a cheaply made 2 ton jack. It will be rated at 2 tons, but there will be so much play in the linkage that the handle will move 6 inches before it starts pumping the hydraulic cylinder. I bought a cheaply made one years ago and I could not lift my Mustang GT because there was only limited room for the handle to swing under the air dam when the jack was under the rear diff. I returned it and bought a better one and the good one lifted with no problem. The cheaply made ones will usually be sold by Kmart/Wal-Mart type of stores. Some of these require you to pull out the pump handle from the pump and put it onto a valve for up/down control. Don't buy those. A good floor jack will raise or lower by twisting the handle. It's hard to line up the valve with the removable handle when most of the jack is under the car! There are inexpensive ones that are good, so shop around. Craftsman has good ones, also there are some pretty good inexpensive ones at Harbor Freight.
Steve
Old Mar 28, 2007 | 03:21 PM
Valid points, fastsuv....
Made me think of the ONE THING that I look for first...... ANSI approved. Much of the China and foreign country "junk" is not approved. Some is, and quite good....but it must have this approval for my satisfaction and peace of mind.
Old Mar 28, 2007 | 06:45 PM
SandyBeach's Avatar
Don't you always balance your tires at the same time you rotate them? I learned the hard way that balancing is very important, especially on aluminum wheels with stick-on weights.
Old Mar 28, 2007 | 07:04 PM
SindyDix's Avatar
If you plan on lowering your HHR, you'll need a low-profile type jack. Just something to think about before you plop down your money for a regular one.
