Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
I only post in speculation, as I cannot touch the fluid, smell the fluid nor pop that wheel off and inspect the wheel cylinder for leaks, it could be that.
But from here it looks like some sort of lubricant to stop the wheels and or drums from getting stuck on the hub.
As we see hear there is no seal near the hub flange were the studs are!
A few weeks ago I had the car at a repair shop. One thing I asked them to look at was the rear brakes because I was getting a squealing noise when I applied the brakes in reverse. (No squealing if going forward.) They sort of fixed that by applying grease inside the brake drum and adjusting the brake shoes. There was no squealing for awhile but it has returned but not as bad as before. So I suppose the present leak might be the grease they applied.
No FMG, no joke!
Now remember your SS has rear disc brakes, the OP has drum brakes, and there are lubrication points on the backing plates were the shoes contact them.
This will stop the squeaking when the brakes are applied.
OK. I guess I misread that. Sounded like the OP was saying they put grease
ON the inside of the drum.(as in, on the drum surface)
Yeah Oldblue. Very familiar with those lube points. Remember, I'm from the older generation. When I was turning wrenches for a living way back, most cars had rear drum brakes. Heck lots of them still had 4 wheel drums.
Thanks. Now I feel old.
FYI. Brake squeals are caused by friction vibration. Fix the source of the vibration to eliminate the squeal.
Well, all we can do is offer written advice and suggestions, such as check for brake fluid leaking from the inside of the drum, checking brake fluid level, and hey how about pulling the wheel off and taking a closer look.
