needed torque specs for engine replacement
Old Apr 21, 2018 | 09:27 AM
jaydevries's Avatar
I have a 2010 HHR SS that I has to replace engine due to a slight engine leak from a connector rod going thru bottom of engine.
So I have ordered a LDK long block from Z Z Performance to replace it. I want to do it correctly by making sure everything is put back correctly.
Can anyone give me some tips that might help from their experiences with this and all the necessary torque specs needed.
Attached Thumbnails needed torque specs for engine replacement-20170318_144556.jpg
Old Apr 21, 2018 | 10:15 AM
Impressive!
Old Apr 21, 2018 | 10:23 AM
Shop repair manuals are your friend.
Old Apr 21, 2018 | 10:29 AM
https://www.chevyhhr.net/forums/how-...e-items-54648/
I had posted it here, but the OP didn't seem to need it that bad.
Old Apr 21, 2018 | 10:33 AM
I copied your post into the torque how-to, donbrew, good info!
Old Apr 22, 2018 | 09:18 AM
DrLoch's Avatar
Originally Posted by donbrew
Impressive!
I'm impressed myself. How may miles were on it? What were you boosting?
Old Apr 22, 2018 | 09:30 AM
Yep. I'm impressed because the rod exited through the bottom.
Old Apr 22, 2018 | 09:44 AM
DrLoch's Avatar
That'll bring out the caution everytime. Quite a feat, I've not seen an LNF do that.
Old Apr 22, 2018 | 10:39 AM
I was trying to figure how the wrist got all the way down there.
Ain't it great when you fulfill a request like that in an hour. And the requester never even returns to look at it, much less a thank you.
Old Apr 22, 2018 | 04:43 PM
jaydevries's Avatar
Thank you very much for all the help. this will be a great help for now and future use.
ok so next question to lift or drop engine
