stereo wiring help
stereo wiring help
hi everyone. i've been coming to this forum for quite a while, but this is my first post. i've had my hhr for a little over a year and a half and am finally getting around to putting in a stereo system. i've been reading a lot of posts about wiring and have decided to hard wire my cd player. the only questions i have is with the system remote wire and the acc wire. with the remote wire, do i wire it to both my amp and the radio antenna trigger or just the amp? and with the acc wire coming from my cd player, where do i run that to exactly? i saw also that SoCalHHR said in a post that he had a very easy to read wiring schematic. if anyone has that and could send it to me, that would also be helpful. thank you and i must say this is the best place for anything hhr.
The acc wire is to be a brown wire in the ignition column, or you could use slot #21 in the fuse panel that turns on and off with the key using a add a circuit.
Not sure about the antenna trigger. We don't have a power antenna so I don't see a point in using it. But your remote wire hooks straight to the amp. I'd try that and see how everything works.
https://www.chevyhhr.net/forums/show...d+power+source
A picture for anyone that maybe not know what it looks like.
Rogoflap
May 14, 2010 02:03 PM
