where to put Switches?
Old Jun 25, 2008 | 02:14 PM
mchuntley's Avatar
I am considering some mods, and one of them is adding an aoogah horn. I want to leave the original horn in place for the time being.
I have a couple of other ideas for things to wire up, but I am wondering where to put the switches? I want it to look good.
I am tempted to put them in the upper glovebox, since that way they are hidden.
Any other ideas or how did you do it?
Thanks,
Matt
Old Jun 25, 2008 | 02:17 PM
What about in this area or the other side of the column?
Old Jun 25, 2008 | 04:11 PM
Cajun's Avatar
How about on the panel below the steering column....easy to reach
and out of direct sight.
Cajun
Old Jun 25, 2008 | 09:06 PM
mchuntley's Avatar
I was looking down there.
The only reason why I have not planed for there, is during an accident(heaven forbid), you can get impaled on things down there. I keep leaning toward inside the upper glove box. Or maybe building a flat panel that sits in the change tray...
Old Jun 26, 2008 | 02:19 AM
Cajun's Avatar
There is that retangular slot on the console between the seats...what's that for anyway..? LOL
Cajun
Old Jun 26, 2008 | 05:57 AM
Jeff®'s Avatar
Holy crap! No offense, but that be fugly!
Old Jun 26, 2008 | 07:58 AM
SLVR FOX's Avatar
my interior cathode switch i put in the cig lighter in the dash. i don't use it, and the switch looks factory. my UB switch is tucked up under the steering column.
Old Jun 26, 2008 | 01:30 PM
ColeTrickle's Avatar
I would do something that looks factory. also always wise to drill holes in peices that are easy to replace and easy on the pocket book:)
Old Jun 26, 2008 | 01:40 PM
Dremin2flyhi's Avatar
here is one way to do it if you dont wont a switch showing... its pretty neat little trick... I use this for turning on/off some cold cathodes and led lighting in my interior.. works very nicely and is hidden from view... its a basic single channel remote relay for up to 15amps 12vdc...
http://store.pcwebshopper.com/lorm12v15are.html
Old Jun 26, 2008 | 04:42 PM
Cajun's Avatar
Remote control switchs....great idea...
Cajun
