How to get through Firewall
Old Jul 7, 2008 | 10:18 PM
Stingeralt10's Avatar
I only found one realated thread to this question, and it wasn't really a big help. Is there any way (without drilling) to run wires from my battery to the inside of my car through the firewall. The closer the wires come in to the passenger side the better but if drivers side is where the hole is i can make that work. Thanks!
Old Jul 7, 2008 | 10:42 PM
Hays Hot Rod's Avatar
No need to go through the firewall, Our battery is in the back with the spare tire. Take out the cargo shelf and the panel under it and look in the right corner.
Old Jul 7, 2008 | 11:02 PM
Yeah i noticed that. But then i have to run the wires all the way to the font. It possible but not optimal. Going form front batery to passanger side is only about a foot. From the rear battery that would be about 4 or 5 feet. So the question remains.....
Old Jul 7, 2008 | 11:21 PM
ecl's Avatar
ecl
there is no front battery its only in the back as far as know.
Old Jul 7, 2008 | 11:25 PM
twistrman's Avatar
yeah the battery is in the cargo area but you have the positive and negative terminals under the hood.
In the HHR? The battery isn't in the hood? Located right under the fuse box? B/c there is definitly a red and black (positive and negitive) port to attach wires too.
Old Jul 7, 2008 | 11:37 PM
Yonash's Avatar
those are remote jump terminals. since the battery is in the back (if you don't believe us, go check), and the hatch is 100% electronic to open, if your battery dies, you can't get to it for a jump, so they thought ahead and gave us connection points under the hood for jump starting.
Old Jul 8, 2008 | 12:05 AM
haha wow.. NEVER would have known that. I thought I had two batteries. (sorry, not much of a car guy) Thank you very much... so if i was getting a sterio system installed they would have to run everythign from the battery in the back?
Old Jul 8, 2008 | 12:34 AM
xzombiex66's Avatar
Yeppers
Old Jul 8, 2008 | 07:18 AM
an08HHR's Avatar
Depending on how much "power" you need, you can get power from the passenger fuses (namely fuse #21 which is 'on' when the ign is 'on'). Those fuses on located on the right side of the center console behind a panel.
If you need a on line manual to locate this fuse, here is the thread for a manuals https://www.chevyhhr.net/forums/general-hhr-4/online-owners-manual-3074/
