Premium Sound system install?
Old Jan 2, 2009 | 04:40 AM
ebritt's Avatar
Maybe it's been asked before but after being on here for hours searching my eyeballs are drying out....so here goes.
I have the factory Single cd 6 speaker system in my car. is the wiring there for the premium system? if not how hard to install?
I want to keep the factory setup so I can use steering wheel controls and factory sub.
Do I have to have the premium head unit or can mine be wired into sub with some creative wiring?
Can i get a factory sub and box and tap into existing head unit with aftermarket amp?? Or even aftermarket speaker in factory box?
Any help is greatly appreciated.
Old Jan 2, 2009 | 11:40 AM
masterchief1112's Avatar
as far as i remember reading rewirin the premum intor your system is a pita. you have to run all the speaker wires to the amp then back to the speakers. easier to just use this method https://www.chevyhhr.net/forums/audio-video-17/how-hook-up-amp-sub-woofer-setup-without-affecting-existing-premium-sys-10944/ and install a line level converter.
Old Jan 2, 2009 | 12:24 PM
Chevy SS's Avatar
If it's bass you want I would just get a aftermarket sub/amp and go from there.
If you want some really good info go to crutchfield.com and e-mail them, they have really helped me in the past. They are a tad spendy so I usually don't by from them, but they are helpful!
Old Jan 2, 2009 | 02:33 PM
djmoose's Avatar
The answer is no. The premium wiring is not there. In fact, the car-side harness that plugs into the head unit is even different.
It's possible...I guess..but to answer your question, no, it's not there.
Old Jan 2, 2009 | 06:37 PM
Eric B's Avatar
why not get a RF 360 to keep your stock radio? and id rather find my own sub/amp combo than get a stock sub..
Old Jan 2, 2009 | 06:43 PM
Fuzzbuster's Avatar
And you can keep steering wheel controls with any high end head unit with a remote
Just need the IR adapter for steering wheel control
Ant car audio shop sells `em
Old Jan 3, 2009 | 12:53 AM
ebritt's Avatar
Ok , still couple questions....
1. If I install an after market sub, what do I need to put it in factory location....I assume I will need the factory box to mount it in? Can that be purchased separately?
2. If I hook the sub into factory 6 speaker system...tap into the front or rear speakers for best sound?
3. I do have a head unit with remote laying around...what is IR adapter to use steering wheel controls?
Thanks again guys.
Old Jan 3, 2009 | 01:08 AM
1. factory box can be found on ebay or just watch the buy sell forum
2. personally i would say tap into the rear so that you dont loose any sound where you are at the most. in the drivers seat.
3. this is a steering wheel controll adapter from crutchfield. i have heard good reviews here about it. http://www.crutchfield.com/p_127SWIX...X.html?tp=3405
Old Jan 3, 2009 | 01:22 AM
ebritt's Avatar
Thank you very much....Im gettin right on it.
Old Jan 3, 2009 | 06:31 AM
just to add if you cannot find the box cheap here or ebay you could always go to the dealer or check online parts places.
chevyss
Feb 18, 2012 11:04 AM
jgoldwood
Mar 18, 2010 10:56 AM
damienSS
Oct 1, 2008 12:27 AM
