Sound Deadening
Old Jan 24, 2009 | 09:58 PM
Chevy_dork04's Avatar
Sound Deadening
whats the best cost effective way to add good sound deadner to all the doors and possibly rear hatch....
Old Jan 24, 2009 | 10:11 PM
masterchief1112's Avatar
dynamat. none in the hhr yet. but had it in the truck and it worked pretty well
Old Jan 25, 2009 | 12:32 AM
IgottaWoody's Avatar
RAMmat is better and cheaper....go to the site and read it up..he did a comparrison on all the better deadeners.....
Old Jan 25, 2009 | 09:53 AM
hugheshhr's Avatar
Im using Raamat in my HHR. I got a 50ft roll for 140 shipped. Its great stuff. Its a little on the thin side but it works good.
Old Jan 25, 2009 | 10:08 AM
Brwbier's Avatar
I have never seen either product but from the pictures to me it looks like "Ice Dam" a self stick roofing product. Is this generally the same thing or would it work the same?
Old Jan 25, 2009 | 10:20 AM
hugheshhr's Avatar
In a roundabout way it could be in general the same. Sound deadening is an asphalt based product with the adhesive on one side. So generally yes same thing. The Raamat bein a thinner product is more pliable and easier to mold without a heat gun to conform to panels.
Old Jan 25, 2009 | 03:18 PM
Ed RazorLite's Avatar
Dynamat is very expensive and not even the best out there.
asphalt based deadeners are good but still not the best.
Raamat is good stuff, I have used it in the past.
But the best by far I have ever used is Second Skin,
The damplifier Pro is a foil backed butyl based mat. it has score lines so that when you adhere it down and smotth it, air can escape from underneat. This allows for a perfectly bonded surface/
Butyl is not effected by heat. asphalt based deadeners can melt and become soft.
Second skin also makes a liquid that can be painted or sprayed on. Its good for tough areas to stick you arm into.
www.secondskinaudio.com
Old Jan 27, 2009 | 12:43 PM
PhoS's Avatar
Rammat for sure , lots of it.. The HHR doors sound like a bucket of legos once you get some power into your system...
Old Jan 27, 2009 | 01:58 PM
where do i get rammat , and whats it take to install it in all the doors?
Old Jan 27, 2009 | 04:29 PM
jshandra's Avatar
I used secondskin also, works great!
