Xm Antenna / Sirius Plug N Play
Old May 29, 2006 | 10:15 PM
jerij's Avatar
I spliced into my XM antenna lead this weekend and hooked my Sirius Starmate up to the XM antenna. I'm getting 3 bars out of 8 on my satellite, and about 5 out of 8 on the terrestrial. When I was manipulating the connections, it seemed to make a difference how much wire I used to do the interlacing. Something tells me I should have ordered the connector that one our members sells, but never got around to it.
Does anyone know if it would be worth the trouble and expense to try to mate the 2 ends together with a connector instead of just "splicing" like I've done?
If it's not going to make that much difference I'm not going to the trouble of ripping all that **** out again just for another bar or 2. I'm getting virtually no dropouts in the city where I have repeaters, but my rural parents was a different story. Around hills, trees,etc it got irritating.
Anyway, the good news is, it works. Now I only have 3 antennas on top of the car instead of 4....
jerij
Old May 29, 2006 | 10:18 PM
ng8650's Avatar
3 antennas = XM/Sirius + AM/FM + ?????? What's the third for?
Ng
Old May 29, 2006 | 10:20 PM
jerij's Avatar
AM/FM
XM
Onstar
And before this weekend I had a Sirius antenna on top also.
Old May 29, 2006 | 10:32 PM
ng8650's Avatar
Someone needs to come up with a way to combine all these antennas into one! I know I would buy one!
Old May 29, 2006 | 10:37 PM
jerij's Avatar
The trouble is, you will have a hole in the front or back of your car left over.
I guess it could come with a plug of some sort, though.
An odd thing I noticed was the front AM/FM antenna goes all the way to the back of the car where the Onstar unit is housed, instead of up front to the radio itself.
God, I wish Helms would release a service manual for this car!
jerij
Old May 29, 2006 | 10:59 PM
ng8650's Avatar
One of my future projects is to have a body shop shave the rear wiper. If I could I would also shave the front antenna but someone needs to combine satellite and AM/FM for me to do that. Or move that antenna to one of the fenders???
I don't even listen to AM/FM anymore so I could really go without that contraption. But Murphy's law...the day I get rid of the analog antenna is the day satellite radio probably stops working
Ng
Old May 30, 2006 | 07:34 AM
joesblackhhr's Avatar
Exclamation
jerij
when you say spliced did you cut the wires and just twist them together??
because of the frequencies involved for satellite and the minute signal strength you may have created an impedance bump and mismatch.. it is always best to use connectors and leave the cabling uncut...
Old May 30, 2006 | 09:37 AM
jerij's Avatar
That's what I was trying to figure out. If it was going to be worth the effort to attach plugs to get the proper signal strength, I'd go to the trouble of finding the connectors and tearing the panels out again.
jerij
Old May 30, 2006 | 10:54 AM
Also there were some comments and questions about using an XM anternna with Sirius elsewhere in the forum... I think I remember some guys said it would work,, others thought there was some kind of mis-match.. search the forums
Old May 30, 2006 | 04:03 PM
jerij's Avatar
It does work. I'm using it now with my Sirius Starmate.
jerij
