Got my steering wheel radio controls!
Old Oct 1, 2009 | 09:34 AM
HHR_style's Avatar
I just recieved my leather wrapped SS Cobalt steering wheel last nite
I like the smaller diameter. I lined up the bottom edge of each wheel & took this pic:
I wrapped a tape measure around each wheel & the 'Balt wheel is approx 2.5" smaller O.D. (28-stock, 26.5" 'balt).
I wanted the smaller OD mostly (& the leather) but the radio controls will be a welcome addition
I bought it off eBay for $104. total (free ship). I wanted black leather & they had two listed. A 2006 model & a 2008 model. The pictures they gave were generic so I didn't know what they looked like or if they came with all buttons etc. I chose the 2008 model but I think I got the '06 wheel because the buttons are lower profile than my '07:
But the wheel is fresh looking. Hardly a scratch on it. The leather is in excellent condition:
I didn't have the guts to try the install last night. I'll probably tackle the job this weekend so I have time to work it out. I'll post up install pics when I'm finished. Wish me luck!
Old Oct 1, 2009 | 09:36 AM
txbass06's Avatar
Good luck with this. I've been wanting to do the same thing to mine. Let up know how it turns out
Old Oct 1, 2009 | 09:00 PM
HHR_style's Avatar
1st snag right out of the gate!
OK so I'm in the mood to do this install. I get the horn/airbag off easy. Piece of cake. Now I need to remove the plugs from the back of the airbag.
Bam They are on there good. Does anybody know how to remove these little clips (so I dont bust them all up with my fat fingers)
I see little tabs on the sides of each clip. They have a slight texture to them. As if I need to compress them in or something
But I pull & twist & they aren't budging. Can somebody please tell me how to take these plugs off? Thank you
Old Oct 1, 2009 | 09:11 PM
lunchbox's Avatar
If i remember correctly, i just pried up the little yellow clips with a small flat head screw driver, and the grey wire terminals just popped right out. It's been a while since i changed mine out, so i'm not 100% sure, but that might get you going in the right direction. Just look at it for a while and see if you can figure out how it comes apart. I did mess up one of my yellow fasteners a bit, so just take your time with em. Good luck.
Old Oct 2, 2009 | 09:03 PM
HHR_style's Avatar
The install moves forward!
OK, I figured out how to detach the plugs from the back of the air bag. The yellow clips pull straight up & out. I used my fingernails to pry upward:
Then I used needle-nose pliers to compress the little tabs on either side of the plug & pull upwards to remove it.
I pulled the steering wheel off by tugging on it a bit. I also used a little WD-40 as suggested by a fellow HHR.net'r (thank you). It finally came off & I now had only one more plug to remove to get the darn wheel off . The blue plug was another one for the pita list. Luckily my new wheel had a plug to look at. You need to clear this little hook:
I used a thin flat blade screwdriver.
With that, the steering wheel was off!
Check the side by side:
The cobalt wheel is smaller but beefier!
Here's a close-up shot of the buttons to show the difference in height. Also note the grainy texture of the stock plastic wheel compared to the buttery smooth leather:
Amother shot of me buttons:
OK On to the installation. I went to plug in the blue plug (for the new wheel) & I notice that all the wires are a different color than the stock HHR wheel. Great! What do I do now? Will my new buttons even work? Oh man, will this project ever get completed?
I'll just have to hook it all up & pray!
Installation was pretty quick. My new wheel came with all buttons & wiring intact. Hey, that's plug - n play
Overall the install should've been easier. Messing with the plugs slowed the entire project down for me. I took a test drive & everything works perfect! Oh Man! The leather. It's like buttah! The smaller diameter feels great. I can still read all gauges normally. The button lights are a slightly different color (yellow instead of blue. cool!). Messin' with my radio buttons now. Oh Man, I can highly recommend this install.
Here are some of the installed pics:
Check the fatness of that 'balt wheel:
Old Oct 2, 2009 | 10:35 PM
c2vette's Avatar
Well done, great mod. Isn't that the same as the HHR SS though (i.e you could use Cobalt or HHR SS)?
Old Oct 2, 2009 | 10:56 PM
HHR_style's Avatar
'baltic
You probably could use an SS wheel but a Cobalt wheel is bound to be cheaper $$.
Old Oct 3, 2009 | 01:45 PM
Dan's HHR's Avatar
nice job and well detailled thanks for sharing
Old Oct 4, 2009 | 09:37 PM
HHR_style's Avatar
*Correction*
Re: Outer Diameter (O.D.). Earlier I mentioned the size of the wheel: "...28-stock, 26 1/2" 'balt". This is incorrect. I found my notes. It should be (approx): 48 1/4" stock & 46" Cobalt. Sorry. Drive on through
Old Oct 14, 2009 | 10:58 PM
hanjin's Avatar
I just got the same wheel from the same ebay seller for 80.00 best offer. The install took about 10 min. and looks great. Thanks for the write up.
