Eibach or Progress?
Old Jun 29, 2006 | 05:57 PM
JOEK86's Avatar
Eibach or Progress?
Other than the small difference in drop, about 1/2", are there any advantage or disadvantages to either? Experiences and thoughts please............
Joe
Old Jun 29, 2006 | 06:01 PM
SoCalHHR's Avatar
Joe, I don't think anyone will have any experience with the Progress springs yet. We just picked up the first shipment yesterday.
Old Jun 29, 2006 | 06:02 PM
captain howdy's Avatar
The progressive ones just hit the market and Eibach still uses the same springs for both the Cobalt and HHR to my knowledge.
Old Jun 29, 2006 | 06:18 PM
JOEK86's Avatar
I have 17 by 8 wheels on my 2LT, do you guy's think I would have any problems with GOLDLINES?
Old Jun 29, 2006 | 06:20 PM
You might have trouble getting a set of Goldlines from what I understand.
Old Jun 29, 2006 | 07:02 PM
SoCalHHR's Avatar
The stock HHR wheels are only 6.5-inches wide. Depending on your new wheel's offset, you will most likely need to roll the fenders with 8's.
I'm running 17x7's with a +42mm offset and had to roll the rear fenders with Gold-Lines.
Again - it all depends on the wheel offset. Look for an 8 with a +45mm offset.
You shouldn't have any issues with the Progress springs - they have slightly less drop:
Old Jun 29, 2006 | 07:14 PM
JOEK86's Avatar
Mike,
I have American racing Rogue wheels with a 35mm offset.
Do you mean that I won't have to roll the fenders with progress?
Old Jun 29, 2006 | 07:18 PM
SoCalHHR's Avatar
Hard to say. You might have to roll as 35mm is a lot LESS offset than stock.
With a wider wheel, you need MORE positive offset to keep the wheels "in."
Cant' really say until you bolt them on...
Old Jun 29, 2006 | 07:38 PM
JoeR's Avatar
Mike... Google is your friend! Look up wheel offset and come back when you understand the relationship between offset, wheel width and where the tire ends up.
FACT: At any given offset the tire tread will be in the exact same location regardless of the wheel width!
On the HHR the first problem to manifest itself is where the outer rear tire will hit the fender lip near the edge of the tread. Wheel width will not change that, only offset.
Old Jun 29, 2006 | 09:39 PM
SoCalHHR's Avatar
Joe - we've been through this before; both online and on the phone....
Your statement only pertains to the absolute center of the tread. A wider tire/wheel combination is still wider - and will rub (especially on a lowered HHR). Increasing the positive offset will tuck the wheels "in" under the car, increasing clearance.
Why not see what the wheel manufacturers are building for the HHR. Most new HHR bolt pattern wheels are being built with 42mm offset on 7" wheels and 45mm offset on 8's. They must be wrong too...
Bottom Line: If you want an 8" wheel on the HHR - you will need to increase the positive offset to make it fits without rubbing against the outer body. (*Just ask any of the guys who have already lowered and done it.)
