Rubbing?
Old Jul 1, 2006 | 06:18 AM
JOEK86's Avatar
Rubbing?
Has anyone lowered there HHR and ended up with the tires rubbing? If so, what set up caused it and which wheels and where did it rub?
Joe
Old Jul 1, 2006 | 07:57 AM
hvrod's Avatar
Joe
Sure..
Lowering it cause it to rub.. I would add , mostly due to the width of my aftermarket tires which were 8.5 wide.
And the shocks loosing its buffer cushion due also to the lowering..
I added coil over monroe shocks.. first, that helped alittle bit...
It wasn't till I rolled the fenders (rear) that everything was fne again..
Hope that helps..
Old Jul 1, 2006 | 11:44 AM
DARK AGE 53's Avatar
Other's here can answer your question better then me but here's what I found on my last lowered Camaro, with stock wheels/tire there was no rubbing....with aftermarket wheels I had on it for a short time ( 50 miles ) it rubbed.
Old Jul 1, 2006 | 01:41 PM
HHR PNOY's Avatar
joek,
if you do a search for "springs" "lowering" "rub" I'm pretty sure you'll see threads that talked about it.
Old Jul 1, 2006 | 01:59 PM
Markiemark's Avatar
Mine is lowered with the Chevy 17" wheels, GOldline springs. One trip with vehicle loaded down, there was a little rub, happening on bumps, when traveling at speed. Rubbed on the top outside of the tire, hitting the inside of the fender. Not much rub, but a little. Several with larger wheels, have rolled inside fender lip.
Normal, not loaded down, I have no problems.
It does stiffen the ride, and some hard bumps, you will definitely feel it.
I still enjoy the lowered look and I am having fun!!!!
Later
Old Jul 6, 2006 | 12:23 PM
crowbar's Avatar
lowered with 20"s = major problems
Old Jul 6, 2006 | 12:27 PM
hvrod's Avatar
Later
Hey.. I like that color...
You need some Monroe .. coil over shocks...
hvrod's Avatar
wow... 20's...
Yep....
Old Jul 6, 2006 | 12:28 PM
HHR PNOY's Avatar
crowbar...what did you do to fix it?
Old Jul 6, 2006 | 12:47 PM
crowbar's Avatar
had to grind away the rear inner fender no problems up front i gotta thread about it round here somewhere
