How to access stereo wires for a dvd head rest monitor
Old Apr 30, 2010 | 03:41 PM
ssalamaca's Avatar
Hello, Didn't know if there was a way to access the stereo wires. We recently purchased dvd headrest monitors, but the only way to install them is connecting the power wire to the +12 volt power supply of the car. I am not sure if it is too hard for me to figure out or I should just take the monitors back. Thanks
Old Apr 30, 2010 | 04:58 PM
comic75's Avatar
I just installed some in mine - the easiest way is to get a fuse tap and hook them up to the sunroof fuse in the fuse box - its in the passenger side of the center console - really easy - and its powered if you have a sunroof or not.
Old Apr 30, 2010 | 08:09 PM
ssalamaca's Avatar
Is a fuse tap used to connect the wires into a slot intended for the fuse? Do they fit into where the fuses are suppose to go? Thanks
Old Apr 30, 2010 | 10:06 PM
sideout94's Avatar
Constant hot
I installed an overhead DVD player and an aftermarket stereo and used the empty #21 slot in the fuse block in the passenger side of the center console. Make sure you plug into the correct side or you wont have any power. It has worked great so far and was alot easier than running out to the main fuse block in the engine compartment. I found pictures and everything on which one to connect to on another post on this site. WHAT A GREAT SITE IT IS!
Old May 1, 2010 | 09:45 AM
ssalamaca's Avatar
Do you remember what post by chance? Thanks
teknolla
Feb 5, 2019 04:01 PM
Jrojas0504
Jan 6, 2013 01:49 PM
ssalamaca
Apr 30, 2010 08:01 PM
Digital_Rapture
0
Jul 18, 2008 09:07 AM
