Radio Removal Question
Old Oct 25, 2011 | 11:31 AM
fastsuv's Avatar
I have a quick question.
Three of the four speakers have gone dead on my (base) audio system. I would have assumed the radio had channels going dead, but after reading some previous threads, it looks like the speakers may actually be failing. I intend to unplug the radio and check the impedance of the speakers at the radio connector.
If I remove the radio and then re-install it, it should work without any reprogramming, correct?
The service manual says that it compares the VIN of the car to the VIN programmed in the radio. I am assuming the VIN programmed into the radio stays programmed into it even if you remove power. But I want to be sure before I disconnect anything.
Thanks
Steve
Old Oct 25, 2011 | 11:32 AM
ChevyMgr's Avatar
Reinstalling the same radio will not require programming.
Old Oct 25, 2011 | 11:37 AM
fastsuv's Avatar
Thanks for the fast reply, ChevyMgr!
Steve
tubejock
Jun 30, 2012 05:42 PM
pyro panel
May 31, 2012 08:32 PM
SoCalHHR
"How To" Tutorial Library
53
Apr 25, 2012 03:32 AM
jethroc
Apr 8, 2012 07:54 PM
Goose
Jul 19, 2008 10:09 PM
