Does std stereo have output for sub?
Old Nov 5, 2011 | 07:27 AM
Dewey's Avatar
I have a standard factory stereo, without the subwoofer, and would like to add a sub. Does the stock stereo have outputs to use? If not, how have you hooked one up without changing out the stereo? Trying to do things on a tight budget :)
Thanks for any info.
Old Nov 5, 2011 | 07:12 PM
prod's Avatar
Nope, factory stereos have no sub output. You need a line out converter, or get an amp with speaker level inputs.
Try doing a forum search for those terms, there are a few threads already posted.
Old Nov 6, 2011 | 04:50 AM
Dewey's Avatar
Thanks for the info. On the amp subject, how big do I need to go? I'm just trying to add a little to the standard setup and want it to balance well.
I have looked at the info on line out converters and amps with speaker inputs and it brings up another question: Can I splice off my rear speakers and still have the rear speakers or do I lose them to run the amp for the sub?
Thanks for any help, it is appreciated :)
Old Nov 6, 2011 | 06:43 AM
prod's Avatar
Feeding a sub amp with rear channels means losing the signal to the speakers.
I used two amps, a 4 channel for the doors and a separate sub amp.
Its not a big deal to lose the rear door speakers though, most pro installations dont use them anyways.
I think a good 10" sub in proper enclosure with 250w would be fine unless you really want to shake your teeth out.
gscott1962
Aug 26, 2011 07:36 AM
Rogoflap
May 14, 2010 02:03 PM
American Misfit
Oct 11, 2009 10:30 PM
Sunrise HHR
Apr 23, 2008 03:24 AM
Moogyzyl
Apr 11, 2007 12:44 AM
