Basic stereo wiring harness info needed please!
Old Jan 28, 2012 | 10:57 PM
jvance77's Avatar
I am sorry if this is covered somewhere here, but i have tried to find the answer in search but came up with none so far. I have a 2008 ls panel l would like to upgrade the stock head unit to a double din, and i don't want the chimes or onstar so i don't want the lan 3 adapter. I just need the wiring harness from stock pins to solder on the new aftermarket head unit connector. I don't want to have to cut off the factory plug incase i need to reinstall the stock HU at some point. If someone could let me know what harness could do this i would really appreciate it.
Thanks
Jeff
Old Jan 28, 2012 | 11:03 PM
SpaceCowboy's Avatar
If you are going to a double din unit it would be in your best interest to buy the expensive harness. This will give you speed sense, reverse output, Rapp retention, and a few other goodies...if you get the axxcess one the steering wheel controls integrator comes pre wired you just have buy the unit. I have an LS Panel and did the steering wheel swap (one of the easiest mods almost a must do) do a search for it. I picked my whole wheel up for 100 dollars leather wrapped.
Old Jan 28, 2012 | 11:47 PM
I have a couple of them 04 things, wouldn't work on my car. I bought a pac 11 the third one, worked good. Whistle at me if thats what the book say's u need.
Old Jan 29, 2012 | 12:19 AM
jvance77's Avatar
Thanks for your responses, and you are right, just do it right and spend a view extra dollars the first go around! Again thanks for helping out a HHR Newbie. Have had Toyota all my life and haven't had to deal with on star or anything other then a plug and play adapter. So i take it that the GMOS-Lan-03 is the correct adapter?
Jeff
Old Jan 29, 2012 | 12:21 AM
jvance77's Avatar
Nice install SS Fan!!! I gues i will have to search and see if i need a GMOS Lan 03 or 04 and I will let you know on the Adapters. Thanks again
Old Jan 29, 2012 | 12:30 AM
Thanks, But I just paid some body, and they were a little challenged by it but it's a sweet running devise now !
not much room in there for the cluster ______, of stuff.
Old Jan 29, 2012 | 09:25 AM
wow you got a lot of stuff going on there
Old Jan 29, 2012 | 09:30 AM
Jeff
I would go with this one if you are getting a navigation unit
Axxess GMOS-LAN-034
GM LAN11 Data Interface Harness
sttcharl
Nov 21, 2010 04:07 PM
jgoldwood
Mar 16, 2010 09:50 AM
ICUFOS
Sep 1, 2009 02:16 PM
gnichols
Jan 2, 2009 09:38 AM
courthousedeb
May 14, 2006 05:40 PM
