Dash Waterfall Panel Won't Re-Attach
Old Feb 11, 2013 | 09:39 PM
jered6323's Avatar
I took the waterfall off to mess with some of the wires behind the Radio. Radio and Heat/AC Controls went back in fine. The top of the waterfall attaches fine, but the bottom 2 clips just do not want to stay in. I've checked all I can to make sure all the wires are going back where they should, but can't for the life of my figure out what's keeping it from going all the way in.
Any suggestions?
Old Feb 11, 2013 | 09:53 PM
gsl54's Avatar
The bottom of the panel must be put in first. There is a tab that must go behind the bezel. Then work you're way up to the top. I did the same thing when I switched head units. I finally figured out how it is done. with the panel off look at the bottom you will see the tab.
Old Feb 12, 2013 | 09:25 AM
prod's Avatar
Yeah, it has to slip in behind the window switch panel first.
Old Feb 12, 2013 | 09:32 AM
skyline26's Avatar
agreed..and welcome back prod, been awhile! :p
Old Feb 13, 2013 | 12:21 AM
jered6323's Avatar
Thanks for the tip! I got it back on.
Thought I was going to break it though. Was tough to get that lip in, then the rod didn't want to go into the notch, between the wiper controls and the 12v outlet, but some finagling got it in.
andoll83
Nov 2, 2008 10:12 PM
Stingeralt10
Jul 14, 2008 12:37 PM
irloyal
Jun 17, 2008 09:56 AM
