Wheel help
Old Sep 13, 2006 | 12:37 AM
inarmywpride's Avatar
Wheel help
Hey guys i have been looking around for a 5 or 6 star wheel like this
http://www.aewheel.com/eagle_alloy_wheels.cfm?id=261
or this
http://www.aewheel.com/eagle_alloy_wheels.cfm?id=305
and i cant find anything that fits the hhr.
Zentti had something but now they dont cary it. I want 20's for my hhr just something simple and nice so you all know of any wheels that fit and are like theses?
thanks
Cory
Old Sep 13, 2006 | 01:04 AM
courthousedeb's Avatar
Have you tried the site that has the wheel visualizer?
https://www.chevyhhr.net/forums/tires-wheels-49/wheel-visualizer-hhr-2823/
Also, you might try our supporting vendors. Truckshop.com might be able to hook you up.
Old Sep 13, 2006 | 01:22 AM
cj krause's Avatar
Try
http://www.discounttire.com/dtcs/sea...vid=009328&bp=
this is where u can see them on your car
http://www.discounttire.com/dtcs/interactive.dos
tire rack visualizer
http://www.tirerack.com/upgrade_gara...6&autoModClar=
Old Sep 13, 2006 | 07:57 AM
O6ChevyHHR's Avatar
yea use tire rack and go to Americanracing.com they have an app giude. Discountwheelwarehouse.com is also a great website.
O6ChevyHHR's Avatar
I am going to get 20 by 7.5 American Racing Casnios
Old Sep 13, 2006 | 08:31 AM
KY Dave's Avatar
I found these NASCAR wheels on that site. Will these fit my stock 16 inch tires, and will these bolt on my HHR as far as offset and bolt pattern? I was thinking of reworking that center cap with the HHR logo.
Man I like these wheels.
Wind Tunnel
16X7 5-110 38SM (68947)
$120.00each
http://www.discounttire.com/dtcs/fin...bp=&vid=009327
Old Sep 13, 2006 | 10:50 AM
They are the right size and bolt pattern, but the standard offset on the HHR is 42 and those are 38.
Old Sep 13, 2006 | 11:27 AM
KY Dave's Avatar
That's what I thought Deb, but I didn't know what that meant or how important that would be. I DO NOT want the wheels to rub when turning etc. I'm from the old days when a Chev bolt pattern fit just about any Chevy and you didn't have to worry about anything else. I know manufacturers will promise anything to sell a product and give you hell when you try to return it. I would rather not buy if it isn't perfect.
Old Sep 13, 2006 | 12:18 PM
SoCalHHR's Avatar
+38mm offset wheels will "stick out" slightly more than the stockers (7mm to be exact). While that might not seem like much, consider that you will most likely be going to wider tires, which increases the possibility of rubbing. Addittionally, the stock HHR wheels are really only 6.5-inches wide, so going to a real 7-inch rim does make things wider. I recommend going with a +42mm offset on 7.inch wheels and a +45mm offset with 7.5's.
Hope it helps,
Old Sep 13, 2006 | 01:46 PM
KY Dave's Avatar
Yep, that helps alot. Thanks Mike.
