2010 upgrade
Old Jun 10, 2013 | 11:55 AM
walkowg's Avatar
2010 upgrade
Can any body tell me if you can add the sterring wheel radio controls to the standed raido and if you have done it how hard was it. I know some have talk about doing it on older model hhr but I have not seen it on the 2010 model and not sur if it was only on the upgraded raido.
Old Jun 10, 2013 | 01:59 PM
IgottaWoody's Avatar
I have a 07 LS and a non fancy radio, I added the buttons. Was actually the first thing I did to it. Easy to do and there is a how to thread on this site, with P/N's and how to make sure the wires are pinned in the connector correctly,,,surprised it wasn't a standard option on the 10 models, but then it all depends on how it was ordered. Dont see why you can't as they really didnt change much over the years they were built.
Old Jun 10, 2013 | 02:06 PM
LawDog88's Avatar
Everything you will need is right here...
Old Jun 10, 2013 | 06:14 PM
jerry455's Avatar
did it on my 09 LS, works great did it in July of 2009.
Old Jun 10, 2013 | 08:23 PM
put 2010 wheel with the controls on my 2007 LT, plugged right in works awesome!!
Old Jun 14, 2013 | 10:05 AM
walkowg's Avatar
has any one bought the radio controls parts in the last year went to the dealer to order the parts that are listed in past post and they are not good part # need up dateed part # if any body has them thanks
Old Jun 14, 2013 | 10:07 AM
dealer should be able to provide superceeded part number , or they may not be available any more
Old Jun 27, 2013 | 09:28 AM
MarkInMLB's Avatar
Super simple
My son and I did our '06 LT1 this past winter using the instructions we found here. If you'd like, I can provide you the part numbers we ordered from GM Parts Direct, but caution that they may not be exact between ours and the '10 (especially the steering wheel cover -- different color I believe).
Old Jun 27, 2013 | 07:34 PM
walkowg's Avatar
that would be great
Old Jun 28, 2013 | 02:47 PM
MarkInMLB's Avatar
Part numbers that work for an '06 LT1 (Tan interior)
Here you go. As I said, these were ordered (Nov. '12) for and installed in an '06 LT1 with a tan interior. I'd definitely verify with a dealer or GMPD that they'll work for your '10, as I thought I remembered something in that long thread about the harness changing or something (and the cover color is definitely different if you have the gray interior). Good luck, my son is quite happy with this addition.
15842365
SWITCH
$28.13
*25812392
COVER
$19.85
*15234343
HARNESS
$12.33
