08 SS code issues
Old May 28, 2018 | 01:25 PM
Cat Man HHR's Avatar
Originally Posted by DrLoch
IAT sensors in it used to sense inlet air temp so it probably thinks it -38 degrees outside. While not good for the engine and plugs, it will definitely hurt the CATs.
Good thought about the Intake Air Temp sensor. But if was disconnected wouldn't throw a code ?
Old May 28, 2018 | 02:01 PM
Yes it should trigger a code if it’s disconnected or faulty
Old May 31, 2018 | 09:49 PM
OregonHHR's Avatar
Spark plug question
Just got my 08 SS last week and been fighting a running rich codes so I just thought I would change the plugs and this is what I found. Fouled plug
Old Jun 1, 2018 | 12:13 AM
And what is the question?
edit: Oh, you already have a thread about this issue - merging the two threads.
Old Jun 1, 2018 | 07:47 AM
DrLoch's Avatar
It's running rich, but you already knew that.
Old Jun 1, 2018 | 07:59 AM
What plugs are those, the whisker looks different. Hhmmm. Wrong plugs?
Old Jun 1, 2018 | 07:18 PM
I think it would look better in focus. If those are the wrong plugs, boy is that a very cold heat range.
Old Jun 1, 2018 | 07:35 PM
OregonHHR's Avatar
installed the upstream o2 sensor and replaced the plugs and so far so good . Thank for everyone's help. Now on to the mod's.
Old Jun 1, 2018 | 07:46 PM
Well. At least tell us if those old plugs were the wrong ones. And, also let us know if the replacements are the correct AC Delcos.
Old Jun 2, 2018 | 07:17 AM
OregonHHR's Avatar
The old plug was a AC Delco number 41-108 also has number 12620540 on them. Rockauto listed them as for an 08. The ones I purchased are 41834 and they are correct for the car.
