Boost gauge going backwards.
I noticed last night that my boost gauge isn’t working properly. It sits steadily at about 3lbs of vacuum at any speed/rpm, until I give it enough throttle to spool the turbo.
It it doesn’t do anything until about 7(ish) lbs of boost and then it suddenly goes full vacuum all the way until it is reads around 30lbs of “boost”.
Not throwing any codes or having any performance issues.
Has as anyone seen this before? I haven’t touched anything on the gauge pod in about 7 months and haven’t done anything else electrical. It worked fine until it suddenly didn’t.
Pretty sure I remember the plug will only go 1 way. Don't think you can get it backwards.
If he has another SS owner nearby, he could "borrow" their gauge for a test. Very simple to pull the pillar pod off.
Found an old picture.
rustles
Maintenance and Upkeep
12
12-06-2016 01:21 PM
