2008 Yaw Sensor
Old Sep 28, 2021 | 05:38 AM
rorr's Avatar
To answer your question about where your yaw sensor plugs into, in the SS, it ties into the steering angle sensor and the EBCM.
Robert
Old Sep 28, 2021 | 07:16 AM
Thanks for the schematic, that should be very helpful.
Old Sep 28, 2021 | 07:49 AM
fastsuv's Avatar
Thanks for the schematic, rorr!
Is this from a 2008 or 2009-2010 ?
I am asking because they changed the Yaw sensor on the 2009-2010 models from the one used on the 2008 models.
Thanks
Steve
Old Sep 28, 2021 | 09:58 AM
That is the same as 2010, I didn't look at any other years.
Old Sep 28, 2021 | 10:41 AM
I don’t know if the yaw sensor if a different part number , that the wiring is different. It might be.
Old Sep 28, 2021 | 12:56 PM
Some things changed for 2009 model year. If it is an SS, some of those changes happened in 2008. I don't think there is much if any, changes to the SS from 2008 to 2009.
Old Sep 28, 2021 | 03:22 PM
Just the part number for the Yaw sensor. I’ve asked around and the 2008 version is just not available.
Old Sep 28, 2021 | 04:36 PM
Looks like the part number is 22733617
I found this https://www.aliexpress.com/item/2020949732.html
This site gives some interchange numbers https://www.yoyopart.com/oem/11920775/gm-22733617.html
Old Sep 28, 2021 | 05:58 PM
Here is the schematic for 2008 SS:
Old Sep 28, 2021 | 06:37 PM
This is a different circuit in the 2008 SS harness
Different circuits in the cross over, not only for wires, but from different terminals as shown here in the 2009/2010 SS harness
