299 codode underboost
Old 09-08-2018, 12:37 AM
bdfab.com's Avatar
299 under boost hit 10 lbs. then falls on it's face
bdfab.com is offline
Old 09-08-2018, 08:31 AM
Technical Moderator
And .........?
donbrew is offline
Old 09-08-2018, 08:53 AM
bdfab.com's Avatar
299 code
10 lbs. Of boost is Max. Hits 10 then falls on it's face, no boost no acceleration. Getting worse and is shifting. I bought a actuator kit have not put it on yet.
Old 09-08-2018, 09:14 AM
Cat Man HHR's Avatar
Did you check hose clamps that hook up to the turbo, intercooler and throttle body ?
And what do you mean "Getting worse and is shifting" ?
What actuator kit are you referring to ?
Cat Man HHR is offline
Old 09-08-2018, 09:40 AM
Technical Moderator
You have to use your words, we can't guess what you are looking for.
I am assuming the code in question is P0299?
donbrew is offline
Old 09-08-2018, 09:41 AM
Hmm. Not even sure what those 2 above mean, (in blue)
Maybe add a little detail to your post. Start with the year SS and transmission, then some better details to the problem.
firemangeorge is online now
Old 09-08-2018, 01:28 PM
Possibly a trashed turbo, if it is P0299
https://www.obd-codes.com/P0299
Oldblue is offline
Old 09-09-2018, 07:34 AM
DrLoch's Avatar
Broken, how do I fix?
DrLoch is offline
Old 09-09-2018, 09:20 AM
Technical Moderator
Here is the basic fix>
donbrew is offline
Old 09-09-2018, 10:24 AM
Let's see if the person chimes back in.
Quick Reply: 299 codode underboost
