antifreeze all over
Old May 18, 2010 | 07:48 AM
partspeddler1's Avatar
antifreeze all over
lost my antifreeze the other day,didnt see anything on ground but temp gauge pegged so i pulled over and added a gallon got home ant s dripping.haveing too many mods to worry about warrenty,i took it apart and the left lower hose had rubbed through on a casting boss on the block.warrenty for sure but now shes all apart in my garage and no hose till friday.tight getting at it all for sure
Old May 18, 2010 | 03:35 PM
asanti's Avatar
Pics of the rub-through spot? (man that just sounds wrong!)
Later
Allex
Old May 18, 2010 | 05:36 PM
steven&cat's Avatar
Tell us what year and engine so we can see if we need to check ours.
Old May 18, 2010 | 05:43 PM
mightymouse's Avatar
pretty sure they are all the same,assuming he has an ss.
Old May 18, 2010 | 08:38 PM
hyperv6's Avatar
It is a SS thread and they are all the same.
Old May 18, 2010 | 09:05 PM
IgottaWoody's Avatar
Great.....
Old May 19, 2010 | 12:58 AM
Perhaps you could cut a piece of the old hose as a collar, to protect the new hose in that area..
Old May 19, 2010 | 06:00 AM
hyperv6's Avatar
I would often find molded hoses not available for some new cars and would take the old hose to the parts store and match it up to one that would work and just cut it to size.
It happened on my Moms car once and the guy said he had no hose. I asked to look found a hose asked for something to cut it and showed him he had a hose.
Often many hoses are similar in size and shape just different in length.
Something to keep in mind if you are stuck.
Now there are some hoses that you can't just match too.
Old May 19, 2010 | 06:50 AM
antifreeze
the rub through was on the inside top of the very lowest hose.there is a plastic tee and it was just below that.a small boss sticking out .I am going to grind it off and put a collar protector on it in that area
jdjaa1959
Maintenance and Upkeep
Nov 29, 2015 04:30 PM
Gsus
Jul 15, 2014 10:51 PM
06SILVERLT
0
Aug 6, 2010 01:22 PM
HHRcheater
Nov 8, 2007 03:10 PM
