Anyone know the size (12 or 15mm?) of our exhaust hangers?
I just had my Hahn kit put in and it seems to be sagging a bit. I would like to replace the stock rubber mounts with some urethane ones. It appears that they easily come in 3 sizes, 9mm, 12mm and 15mm. Any idea which size? I poked around and it seems like 15mm is the right size? Thanks!
Brian |
Get the 12mm hangers. You can use the hangers that www . kartboy dot com sells for Subaru WRX's and STI's.
Thanks! I ordered a set today. We'll see if that helps with the sag. I think the hangers need to be bent upwards more though.
Brian |
Let me know how thy work out as I'm ordering a set myself.
Later Allex |
Alex, you always beat me to it. I bought new hangers from the dealer, and doubled them up. But these look promising, and hey... red.
Originally Posted by foolmoon_design
(Post 587858)
Later Allex |
I just ordered some 12mm off of Ebay. Will report back when they arrive and are in!
Brian |
Originally Posted by asanti
(Post 587862)
LOL! Well just make note, the red ones are sexy, but they're 15mm, not 12mm so they'd be too long and you'd still get the rubbing!!! (Yup I wanted those too till I noticed the length.) :D Make sure you get the black 12mm ones. :twothumbs:
Later Allex |
I drilled them out to give them a larger opening. However, they are not fitting as snug (on the exhaust side, not car hanger) as I would like. I may end up just ordering the larger ones now.
Can you take a picture of them? Were these universal hangers, or did you find a Kartboy set on EBay? I just received my Kartboy set and will install them later today. I'll take a picture of them and upload them later; on my phone now so it'll be a while before I upload them here..
Later Allex |
