BCM problem? Source for parts?
Traction Control, Electronic Stability Control and Automatic Brake System are not functioning on my 2008 SS. My mechanic says he thinks its the EBCM but that the part is unavailable. Ideas? Advice?
You know that little button on the dash that can turn those things off ? Maybe it’s not working correctly. I would try a reboot of the systems. ( disconnecting the battery. Negative terminal only for safety)
The traction control button doesn't turn off the ABS does it? I get no ABS feedback on the pedal locking up on slippery roads. I get a rotating message SRV ESC; SRV Traction; SRV Brake; ESC off etc. but it all goes away when I turn car off and on. Mechanic says no codes and says sensors appear to be signaling. Says there is a code in "history" that says "EBCM fault"
Mechanic says no codes except a "EBCM fault" in "history." He says pump is working and sensors appear to be signaling. When I lock up the wheels on slippery road I get no ABS feedback and I get a rotating message (see above). The messages first came up during a run up a steep icy hill where the ETC was very active switch back and forth between wheels on various patches of dirt road, sanded ice and fresh unsanded ice. The second time was during mile long run on a slimy deeply rutted dirt road when the ETC either shut off or was not working when I hit the mud. But I found that the messages also start after a simple skid.
ABS will only activate if the wheels are spinning at different speeds while braking; like ice under 1 or 2 wheels. If all 4 lock up there is no need for ABS.
Have the air bags ever deployed?
You describe correctly functioning Traction Control and ESC. You should turn them OFF on slippery roads.
The historic code is from the last time the warning popped up. What is the number?
The BodyControlModule has nothing to do with anything you have cited.
The ElectronicBrakeControlModule controls all 3 with input from the lateral acceleration sensor, the wheel sensors, the steering wheel angle sensor.
If the EBCM was malfunctioning there would be a code.
Every time my ESC activated there was a warning on the dash and the TC light lit momentarily.
