Brake Bleeding Procedure
I visited my library today to look up the Mitchell's Manual for the Brembo brake bleeding procedure. It says to bleed the brakes in this order:
All the brake bleeding I've done over the years, I've always done it "farthest from the master to the closest." That is...
Thanks in advance!
M Ridzon
- Right rear
- Left front (Brembo inboard bleeder followed by outboard)
- Left rear
- Right front (Brembo inboard bleeder followed by outboard)
- Right rear
- Left rear
- Right front
- Left front
Thanks in advance!
M Ridzon
So if I leave the rear calipers alone and do a front caliper swap from non-Brembo to Brembo, I have to bleed the rears in sequence with the fronts? That doesn't seem to make sense to me, but perhaps there's more than meets the eye. Perhaps the rears will be affected by the fronts being opened. Therefore, I'll just play it safe and do them in order.
The MC is split diagonally NOT F/R like 20th century with no ABS and Traction Control and Electronic Stability Control.
So, yes opening the front left means bleeding the rear right.
