Brake pedal has too much free travel or way too soft.
Old Sep 13, 2015 | 07:55 AM
The brake pedal that low after just doing the brakes, sounds like they need a proper bleeding.
Or the master cylinder rear seal sprung a leak after so much travel.
The booster boosts the vacuum to assist in pedal pressure
I don't know how many other GM derivatives have this brake system
Old Sep 13, 2015 | 08:21 AM
Almost every car in America has the same "system". Part numbers may be different.
Any mechanic should be able to diagnose a brake system. If they failed the first time you need a new mechanic.
Don't attempt the job yourself unless you have at least seen it done before. It can be a bit complicated. You have to remove the fuse box to access the master cylinder. The new master cylinder needs to be bled on the bench. Other than that its just turning wrenches.
Old Sep 13, 2015 | 08:25 AM
I think the difference is that vacuum booster, Don.
It is peculiar to just a very few cars
Old Sep 13, 2015 | 08:26 AM
SilverGhst's Avatar
Brake pedal has too much free travel or way to soft.
843de and Oldblue I am going to have the system bled again, makes sense. I am hoping it ends this whole ordeal. Nothing more frustrating then bringing the car to the shop and not having it come back right. One last thing, I am noticing a noise from the master cylinder when I pump it, but hopefully its due to air or moisture in the system. Also, I am going to bring the car to another mechanic, that is never fun either once they see the new calibers. Thanks so much for your input because I am really besides myself on this!
Old Sep 13, 2015 | 09:46 AM
You're welcome, please let us know the outcome of this issue
Old Sep 15, 2015 | 08:26 PM
SilverGhst's Avatar
Brake pedal has way too much free travel or way too soft.
The brakes were bled a second time but did not help. Thankfully when the master cylinder was replaced the issue was fixed! Thanks to everyone and their input! What had me concerned is that I read a posting in a forum where the dealer had replaced the master cylinder and the problem was still there. Also, when I first started looking at the car I did a fair amount of research and I know earlier on there were some problems with the vacuum boost. Thanks again everyone!
Old Sep 16, 2015 | 01:16 AM
Glad to here you're all fixed up now.
Old Sep 16, 2015 | 08:05 AM
Happy news! It's fixed! Now go forth and enjoy a crisp drive through the country and enjoy that HHR!
FMHHR
Aug 11, 2015 10:51 PM
pbatmen
25
Jun 28, 2012 09:21 PM
rocko54
7
Mar 8, 2009 12:24 AM
