Bulletproofing
anything you ss owners would fix right away to avoid future issues??
On my gti the divereter valves would fail so i replaced with a forge mechanical diverter valve, and the pcv failed so i installed a kit to bypass the parts that fail...anything like that with these engines?? |
Get the forge diverted valve.
If it applies to your car, the vacuum brake pump repair.
diverter valve on the list and ill have to look into brake issue
Other weak links are the IC and upper charge pipe.
Yup heard a few people blew out the plastic side tanks on the intercooler.
Kevlar panels.
Originally Posted by hyperv6
(Post 650535)
Kevlar panels.
| All times are GMT -5. The time now is 09:49 AM. |
